3 members (TooMany2count, Bill Hanlon, Gray_Ghost), 32 guests, and 2 robots.
Topics128,029
Posts1,055,417
Members48,422
#369931 02/03/2008 6:15 PM
I am looking for info on what new front spring to get for a s 10 chassis to hold up a 350 sbc. the truck originaly had a 4 cylinder in it, I have gathered up everything else i need, but haven`t been able to come up with what springs to use. any help anyone?? Thanks Mike Bourg
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
I put a V8 in a S10 that had 4 cylinder spring & it looked just fine, BUT normally they say to use the 2.8 or 4.3 springs. I have a 425 Caddy mtr in mine using 4.3 springs w/o a problem..Joe
You can use springs from a '78-'85 Malibu or Monte Carlo V8. Springs from a 4.3 V6 S10 will work, too, seen plenty of V8 S 10s riding on stock springs without any problems.
Also, to get a better ride (especially if you run drop springs), you can use shocks from the malibu on an S10. They're direct bolt ins, just don't need to use the mounting studs for the lower in the rear.
Bill Burmeister
Thanks for the info, i`ll hunt down some 4.3 springs. Mike Bourg
I would love to do a project like that but to use a stovebolt's half ton body.
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Why??????????
Heck I did mine using a 1ton Panel/Bus body...Joe
