| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36878 06/16/2003 7:14 AM | Joined: Jun 2001 Posts: 34 Member | | Member Joined: Jun 2001 Posts: 34 | Messing around with Ruby(my 1 ton panel)today and noticed that my rear tires seemed to fill their respective fender wells differently. I got out a tape measure and checked the diameter of the tires and found that one was 28.5" and the other was 29.0"! Both are Michelin 265/75/R16 same markings,same type. Who woulda thunk it!! Swapped the spare(29.0") for the 28.5" and got rid of a persistant differential whine. I thought that tires with the same stated size would be the same actual size. These weren't cheap tires, so if you have a pesky, peristant rearend noise, it may not be gas... check your tire sizes with a tape. | | |
#36879 06/16/2003 4:08 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I'd make a trip to the dealer that sold them and would ask about the discrepancy.
Fred 52 3600 69 C-10
#36880 06/16/2003 5:12 PM | Joined: Jul 2002 Posts: 385 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 385 | Were these recaps? Are they all running correct pressure? I just can't imagine how new skins coming out the mold could be that far off spec. :confused: | | |
#36881 06/16/2003 7:34 PM | Joined: Feb 2000 Posts: 985 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 985 | When I worked at Pep Boys we had this happen once. 3 of the 4 tires were the same with the forth being 1/2 " smaller. Since we didn't have (and could no longer get) the same tires that the customer had we upgraded them and replaced the tires for free.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
#36882 06/16/2003 7:53 PM | Joined: Jun 2001 Posts: 34 Member | | Member Joined: Jun 2001 Posts: 34 | The tires and rims were given to me so no sweat on the money. They were supposedly take-offs with only a couple thousand miles on them. ( tire pressures were the same) However, I now sense a plot against AD trucks. I have discovered that they were originally on a F**d truck! I guess they are safe now but I WILL be watching them for any further attacks! | | |
#36883 06/16/2003 9:57 PM | Joined: Jun 2003 Posts: 56 Member | | Member Joined: Jun 2003 Posts: 56 | Had the same thing happen on my 25' lowboy GN trailer. I blew two of the new tires and the dealer was never able to get me any that matched the originals. All the new ones were 1" amaller diameter and my trailer had a nice tilt to the right. I solved the problem by blowing the other two, now it is nice and level.
'31 Chevy 1 1/2 ton, '42 GMC 2 1/2 ton 6x4, '52 GMC 2 1/2 ton 6x6, '53 GMC 5 ton
