5 members (Forty9, 3B, TPR57C, Otto Skorzeny, DennisM), 123 guests, and 3 robots.
Topics128,026
Posts1,055,403
Members48,422
#36878 06/16/2003 7:14 AM
Messing around with Ruby(my 1 ton panel)today and noticed that my rear tires seemed to fill their respective fender wells differently. I got out a tape measure and checked the diameter of the tires and found that one was 28.5" and the other was 29.0"! Both are Michelin 265/75/R16 same markings,same type. Who woulda thunk it!!
Swapped the spare(29.0") for the 28.5" and got rid of a persistant differential whine. I thought that tires with the same stated size would be the same actual size. These weren't cheap tires, so if you have a pesky, peristant rearend noise, it may not be gas... check your tire sizes with a tape.
#36879 06/16/2003 4:08 PM
I'd make a trip to the dealer that sold them and would ask about the discrepancy.
Fred
52 3600
69 C-10
#36880 06/16/2003 5:12 PM
Were these recaps? Are they all running correct pressure? I just can't imagine how new skins coming out the mold could be that far off spec. :confused:
1955 First Series GMC 250 1-Ton Panel
Mr. Hedgehog - Follow the build
If you can't laugh at yourself, I'll laugh at you.
#36881 06/16/2003 7:34 PM
When I worked at Pep Boys we had this happen once. 3 of the 4 tires were the same with the forth being 1/2 " smaller. Since we didn't have (and could no longer get) the same tires that the customer had we upgraded them and replaced the tires for free.
Brian Moore
1949 3100 5 window Deluxe
"Today is better than yesterday, but not as good as tomorrow"
#36882 06/16/2003 7:53 PM
The tires and rims were given to me so no sweat on the money. They were supposedly take-offs with only a couple thousand miles on them. ( tire pressures were the same) However, I now sense a plot against AD trucks. I have discovered that they were originally on a F**d truck! I guess they are safe now but I WILL be watching them for any further attacks!
#36883 06/16/2003 9:57 PM
Had the same thing happen on my 25' lowboy GN trailer. I blew two of the new tires and the dealer was never able to get me any that matched the originals. All the new ones were 1" amaller diameter and my trailer had a nice tilt to the right. I solved the problem by blowing the other two, now it is nice and level.
'31 Chevy 1 1/2 ton,
'42 GMC 2 1/2 ton 6x4,
'52 GMC 2 1/2 ton 6x6,
'53 GMC 5 ton
