0 members (),
177
Mod | | | Forums66 Topics128,113 Posts1,056,619 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 18 New Guy | | New Guy Joined: Nov 2007 Posts: 18 | I just found out that my pinion lost part of a tooth and it was catching in the gears in the differential. Needless to say it would make quite a bang when this happened. I have removed the debris, and it seems quiet now, but I will need to replace the ring and pinion soon.
My question is this: Does anyone know if the ring and pinion are the same in a standard differential and the posi-traction?
The truck is a 1961 1/2 ton SWB stepside 2wd 235 4-spd posi-trac.
Thanks for any help.
Joe
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Yes, the ring and pinion will swap on that one.
Bill Burmeister | | | | | Joined: Nov 2007 Posts: 18 New Guy | | New Guy Joined: Nov 2007 Posts: 18 | | | |
