Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
1 members (Ponchogl), 108 guests, and 2 robots.
Topics128,281
Posts1,058,466
Members48,490
Apprentice
Apprentice
Can anyone help me with the removal/replacement of the ignition switch cylinder from within the switch itself? I have then entire assembly out on the bench, but I can't get the cylinder to pop out.
You will need the key to get it out.
Insert the key, take a pin or straightened paper clip and insert it in the small round hole on the front.
Turn the key and pull out the cylinder with the key.
Apprentice
Apprentice
What if I don't have the key? Any other ideas short of total destruction?. BTW, it's a 1950 3100.
Ex Hall Monitor
Ex Hall Monitor
A locksmith can probably help. Also a lot of those old cylinders were worn enough that any key that would go in would turn it. If I remember right it's a Briggs & Stratten key.
Apprentice
Apprentice
Thanks for the advice. I have a key from my 49 that I'll try to use.
