0 members (),
254
Mod | | | Forums66 Topics128,094 Posts1,056,066 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 20 Apprentice | | Apprentice Joined: Feb 2007 Posts: 20 | Can anyone help me with the removal/replacement of the ignition switch cylinder from within the switch itself? I have then entire assembly out on the bench, but I can't get the cylinder to pop out. | | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | You will need the key to get it out. Insert the key, take a pin or straightened paper clip and insert it in the small round hole on the front. Turn the key and pull out the cylinder with the key. | | | | | Joined: Feb 2007 Posts: 20 Apprentice | | Apprentice Joined: Feb 2007 Posts: 20 | What if I don't have the key? Any other ideas short of total destruction?. BTW, it's a 1950 3100. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | A locksmith can probably help. Also a lot of those old cylinders were worn enough that any key that would go in would turn it. If I remember right it's a Briggs & Stratten key.
| | | | | Joined: Feb 2007 Posts: 20 Apprentice | | Apprentice Joined: Feb 2007 Posts: 20 | Thanks for the advice. I have a key from my 49 that I'll try to use. | | |
