| | | Forums66 Topics128,052 Posts1,055,729 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | i was working on my old girl (53 chevy 3100)gutted the cab i was wondewring how to tell what heater i have there are no stickers on it and some kind of weired valve that has coolant lines going into it but does not connect to the heater box it has a nob on it that has a arrow that says warmer.im am going to post pics on photobucket.com i cant get pics linked to threads i post for some reason. thanks in advance for the help
gotta love old trucks
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | There are basically two kinds of heaters, recirculating and fresh air. If your heater is round, it's recirculating. If your heater attached to the kick panel it's the more desirable fresh air type. FRESH AIR HEATER Note that the valve you describe is hard to come by and runs around $200 if you can find one... same for the core. There is a rebuild kit for the valve but if your core is shot, you're going to pay to get a replacement. | | | | | Joined: Aug 2000 Posts: 587 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 587 | Probably have a fresh air heater, since you are describing a heater control valve, it does connect to the heater, but from the other side (engine compartment). | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | hey tclederman. that is the valve i was aking about. thank you everyone it sounds like i have the fresh air heater.
| | | | | Joined: Sep 2007 Posts: 2,644 Shop Shark | | Shop Shark Joined: Sep 2007 Posts: 2,644 | FYI, Those prices are for rebuilding your core... which you will pay dearly for if you don't already have a rebuildable one. | | | | | Joined: Aug 2007 Posts: 121 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2007 Posts: 121 | luckly my heater core and vavle didnt leak. i hope they wont leak when im done with the truck
