8 members (49nut, HandyAndy, Wally / Montana, cmayna, Hotrod Lincoln, GRNHydra, Leo, 1 invisible),
146
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,087 Posts1,055,980 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2006 Posts: 16 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2006 Posts: 16 | Has anyone tried to make a wiring harness just following the wiring diagram in a manual? I was wondering if this is an exercise in futility or with some patience, can I make it look good (and work, of course)? | | | | | Joined: Mar 2006 Posts: 1,703 Shop Shark | | Shop Shark Joined: Mar 2006 Posts: 1,703 | If your vehicle is Stock ...it should not be a problem ...just test fit the wires and loom em up an maybe look into a modern fuse block for on side road emergencies at night it can be hard at times to find a old tube fuse with a modern block ya can score a fuse pretty easy. ..if it is far from stock then i would suggest an aftermarket harness with a modern fuse block . | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | It should be a pretty simple harness if you're comfortable doing it. Just be sure to use the proper size wire if you're staying 6v. 6v requires a larger gauge wire than 12v because 6v moves more amps. I don't know the exact gauges involved but someone here can give you that info.
