2 members (Steelonsteel, Wooley), 141 guests, and 2 robots.
Topics128,167
Posts1,057,020
Members48,458
Greetings,
Several years ago the original motor in my 53 GMC-one-toner went out. I would like to install a new to me motor - am wondering what size to look for considering avalibility of parts to rebuild and all! Any suggestions will be appreciated. I would like to keep it all stock of cource.
A GMC 6 will be the least effort to get back in there. I'm assuming your 1 ton came with a 228. The 248, 270, and 302 GMC 6 cylinder engines will all bolt back in with very little work. My preference would be for a 270 or a 302. Good Luck
If you are going to stay with a genuine GMC I agree with bigbadswingdaddy. If you go Chevy then a 292 with 9.0:1 propane pistons like mine. Long stroke inline sixes should have a race balance done to them reguardless which one you choose. Really makes then stay together longer and handle slightly higher rpms when needed. Some head work and maybe block decking. I had my head ported and polished for better breathability and more torque for climbing and pulling. Will soon have a modest 4 bbl and headers into the 3" exhaust I have.
"I would like to keep it all stock of cource."
Keeping it all stock limites your choices a bit.
Keeping it just stock appearing does open things up a bit more. I odn't recall if a '53 1-ton came with a 228 or a 248, but to stay stock the correct one of those is what you need.
Stock appearing makes the 270 and 302 reasonable alternatives, and if it were me that's the direction I'd probably go. My '55 1st GMC Sububan has the 270 and performs real well with that motor though the original motor was a 248. These motors would be basically a boltin swap.
Henry, how high does your stovebolt rev to, with all that work?
52 GMC 3/4 ton pickup
68 Big Block Vette
68 455 Firebird
