4 members (DadsFirstPickup, 5Window53, carbking, 1 invisible), 139 guests, and 4 robots.
Topics128,214
Posts1,057,489
Members48,473
I'm sticking with the original strait axle in while I upgrade to a small block. Now that my motor mounts aren't on my bell housing I'll need a crossmember to support the front of my Saginaw 4 speed. Does anyone know if a Camaro crossmember will work? I assume there is a difference between the crossmember whether it came out of an auto/manual car. The width should be really close, but I'm not sure about the drop. Any help is appreciated.
1953 Chevy 1/2-Ton 3100 5-Window
1937 Chevy 1/2-Ton
1970 Chevelle
I know a guy that used one in his, but he had an automatic in it. i don't recall the specifics, it was some time ago and he no longer has the truck, but I think he just cut it down to the correct width. Another option would be to use an aftermarket universal fit type.
Bill Burmeister
