| | | Forums66 Topics128,214 Posts1,057,488 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 70 | I'm sticking with the original strait axle in while I upgrade to a small block. Now that my motor mounts aren't on my bell housing I'll need a crossmember to support the front of my Saginaw 4 speed. Does anyone know if a Camaro crossmember will work? I assume there is a difference between the crossmember whether it came out of an auto/manual car. The width should be really close, but I'm not sure about the drop. Any help is appreciated. | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | I know a guy that used one in his, but he had an automatic in it. i don't recall the specifics, it was some time ago and he no longer has the truck, but I think he just cut it down to the correct width. Another option would be to use an aftermarket universal fit type.
Bill Burmeister | | |
