0 members (),
40
10
Mod | | | Forums66 Topics128,012 Posts1,055,315 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36726 10/02/2003 4:36 PM | Joined: Sep 2003 Posts: 48 Member | | Member Joined: Sep 2003 Posts: 48 | Lets say you wanted to build a full pressure 235 that would be a daily driver. The goals are for the truck to have the most performance possible without sacrificing the reliability needed out of a daily driver. What would you do? | | |
#36727 10/02/2003 10:11 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I would go with a moderately agressive cam, Howard M4F grind or more, solid lifters, aluminum timing gears, aluminum pistons, shaved flywheel, a good bore and balance job, Pertonix ignition, Delso 10si alternator, electric fan, Carter AFB and a 4 barrel manifold and fenton headers. That will be nice and healthy, reliable, and outlast a stock build. It will be spendy, though.
#36728 10/02/2003 10:28 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | I just built a '60 235 very similar to what 4on describes. Doing the job correctly will cost between 2500 and 3000 dollars. Powerband is idle to 4000 RPM. Max cruising RPM is 3200. Roughly 180-200 HP and 250-300 ft/lbs torque. Not blindingly fast, but you'll get mucho cool points at the cruise-ins.
chip
Preaching the Hot Rod Gospel according to the 4-stroke apostles:
Suck, Squish, Fire and Fumes
#36729 10/03/2003 12:35 AM | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Yes like Chip says, each time you do it will be around 2500 to 3000.
54 3100 with 235 62 flatbed dump C60 with 261
#36730 10/03/2003 2:46 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Another carb option is the dual Holley-Weber progressive 2 barrel carbs. They will give you roughly the same performance with a little better torque curve in the bottom end. And dual carbs look cooler, plus giving you better fuel distribution to the cylinders.
Fred 52 3600 69 C-10
#36731 10/03/2003 10:57 AM | Joined: Jan 2001 Posts: 1,419 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,419 | I have a .30 over '56 235 w/ "848 head" (last 3 #'s of the head=higher compression), Fentons, 1 Holley-Weber, HEI ignition, '62 3sp+od, '57 3.90 rear (final drive in od, 2.73). I have split exhaust all the way out, no balance tube, 2x30" glasspacks. Mellow sound, can rap if I want to, good power to get up on the on ramp, good passing power. Stock brakes, everything new.
I took a 1500 mile round trip this summer, averaged 18 mpg. Oh yeah, this combo is in a '49 3100 with LT 215 85R 16's. If you don't haul heavy might as well go to a "P" (but I don't think there is a P out there that is as tall as the aforementioned LT's @30.38") for driving comfort. I'm thinking of going to 2X2bbl H-W's on the Edmunds waterheated manifold I have hanging in the garage...but why mess with a combination that work's great? Yeah, I'll do it; I have to see what's on the other side.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
#36732 10/03/2003 11:31 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | 180- 200 hp from a 235 ?That's a bit of a stretch,lol. More like 150 or so for one like described above. | | |
#36733 10/03/2003 3:08 PM | Joined: Jul 2000 Posts: 962 Shop Shark | | Shop Shark Joined: Jul 2000 Posts: 962 | Hey its possible... The production 235 vette engine had 150 HP, and it didn't have a 4bbl, HEI, a shaved head & block and polished head ports. Hey TonyM, hows them shorts feel?
#36734 10/03/2003 7:09 PM | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | Oh, if you are going to do that to a 235 you might as well do it to a 261. Then you get stronger rods and a larger bore, and full flow oil filtration, but pistons may be harder to find. The rest of the work won't cost you any more. That is my plan. My 261 is stock and good right now, and I have a spare 235 in the garage to drop in while I send the 261 to the machine shop.
The 261 had 150 HP stock, and wakes up more with just better breathing. The corvette grind was used on the stock 261 cam and it is still pretty smooth, you could go with a much more agressive cam and still have a good idle. I like mine a lot.
#36735 10/04/2003 4:44 AM | Joined: Jan 2000 Posts: 1,586 Extreme Gabster | | Extreme Gabster Joined: Jan 2000 Posts: 1,586 | In the May 1955 Hot rod magazine,a performance shop dyno tested a 261 engine from stock to a complete full race engine in 9 stages. The stock HP was 114 at 3500 rpm,torque was 200 at 2500 rpm,serious road rocket power.A hot cam,split exhaust, 2 properly set up carbs and more compression gave 157 HP at 4500 rpm and 237 lbs-ft of torque.The maximum out put engine which was considered the limit streetable performance( ported head,bigger valves, big cam ,more compression. was 197 hp and 268 lbs-ft of torque at a low 2000rpm and slowly tapered off to 245 at 4500 rpm.So lets figue the guys dyno was accurate back then and that present Stove engine devolopment isn't exactly state of the art, so you can get around 170 hp on a moderate on a 261 ,the 235 would be 155 or so in the same state of tune I guess.Other than some old 216 dyno tests, I' ve never seen any other published dyno work on a 235/261.I think a custom truck mag did a 235 build a few years ago, maybe that has something more. | | |
#36736 10/04/2003 2:59 PM | Joined: Apr 2003 Posts: 140 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2003 Posts: 140 | Do go with the Howard cam and the Fenton dual exhaust. I suspect the Holley/Weber, either single or dual, might be better for a daily driver. A 261 is a bit bigger, treu, but the 235s are pretty common, so you save a few $.
I wouldn't shave the flywheel. Off-the-line torque is nice.
Another option that would work well on a 6 is a small turbo. 8-) Emphasis on small....
Cheers! George | | |
#36737 10/05/2003 4:09 AM | Joined: Dec 2001 Posts: 215 Shop Shark | | Shop Shark Joined: Dec 2001 Posts: 215 | I have been dreaming about building a high power chevy 250 with turbocharger and ram air intake into a custom fuel injection, 12.5-1 compression, forged pistons, mabe "strike it rich" and add twelve port head triple 2 inch exaust pipes hooked to cut outs and then routed to nice qite muffeler and tail pipe forged balenced crank, connected to a NV 4500 5 speed overdrive  | | |
