Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
4 members (baldeagle, Ponchogl, TooMany2count, Robert Crandall), 48 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
#36721 05/01/2004 4:58 PM
Dah, my brain went blank, when installing pistons with an off set wrist pin does the greater offset face into the crank rotation or away from the rotation? I'm doing an old Limey bike, this one has offsets pins, no marks on the piston for location.
#36722 05/01/2004 5:04 PM
Doesn`t the crank journal line up with the cylinder bore?
What about con rod angle in the cylinder compared to the crank journal :confused:
#36723 05/01/2004 5:31 PM
Thrust face.
#36724 05/01/2004 7:05 PM
The purpose of an offset wrist pin is to get the thrust face of the piston tight against the cylinder wall before the plug fires. If the ignition timing is set before TDC, the offset needs to be placed so the piston loads the cylinder wall before TDC. This means installing the piston with the offset opposite the direction of rotation. If timing is after TDC, the offset needs to go in the direction of crank rotation. If the plug fires while the piston is "floating" in the cylinder, you'll get a piston slap as the plug fires.
#36725 05/01/2004 10:38 PM
Thanks guys,the total advance on these things is around 36 degrees BTDC, the advance at idle is 15 BTDC.British parallel twins (inline)don't use offset pins for whatever reasons,but these pistons are, ok, see what happens,
