1 members (carbking), 103 guests, and 8 robots.
Topics128,021
Posts1,055,355
Members48,420
#36712 08/25/2003 9:36 PM
i know this is off the wall ,but i got a 93 plymoth voyager...and it shimmys really bad at around 35 to 40 mph....is that from bad allighnment?i hope so...i dont wanna do the cv joint or tie rod end thing..lol
#36713 08/25/2003 11:06 PM
could be that and bent wheel, real low tire press,wheel bearings,,just a thought,,,Fred
Redryder pix
My Hotrod
#36714 08/25/2003 11:45 PM
Could also be a bad tire grin
#36715 08/29/2003 10:53 PM
Does it drive OK until 35-40 and then feel like the van is about to shake apart? If so then it is a 99% chance it is a INNER CV JOINT. Try lifting the front , letting the wheels hang and shake the inner joint. You will probably get a loose or grinding feeling as the wheel is turned BY HAND. If so replace the whole axle they are cheaper than just a joint and usually carry a lifetime warrenty at most chain auto stores.
When you replace it undo the sway bar on both sides, remove the 15mm pinch bolt from the balljoint, and PRY DOWN HARD. Be careful you dont mess up the new joint the inner joints are spring loaded internally. also there are no keeper clips on the trans side it will just slide out. You will loose some trans fluid so be sure to have the right type on hand.
Good Luck
Brad
#36716 08/30/2003 2:38 AM
I had the exact same symptoms in my 1995 Caravan. Luckily it was just a bad front tire. It looked fine,(good tread, no bumps or bubbles) but that was the problem. I hope yours is that simple.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#36717 08/31/2003 2:51 AM
why are we talking nopar on the stovebolt page ? that is a shame
#36718 09/03/2003 2:35 PM
a little lower, and pulled the valve cover and found an intake push rod had gone through the rocker. but with the mess of the motor i decied to put a second hand motor with 25,000 km on it.
#36719 09/03/2003 8:42 PM
:confused: :confused: :confused:
#36720 09/03/2003 8:45 PM
Albert...did that fix the shimmy in your go-mobile? :p
Use a big enough catapult and even pigs can fly...remember nothing is impossible, impractical yes, but never impossible.
