| | | Forums66 Topics128,030 Posts1,055,423 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36712 08/25/2003 9:36 PM | Joined: Aug 2003 Posts: 7 Member | | Member Joined: Aug 2003 Posts: 7 | i know this is off the wall ,but i got a 93 plymoth voyager...and it shimmys really bad at around 35 to 40 mph....is that from bad allighnment?i hope so...i dont wanna do the cv joint or tie rod end thing..lol | | |
#36713 08/25/2003 11:06 PM | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | could be that and bent wheel, real low tire press,wheel bearings,,just a thought,,,Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
#36714 08/25/2003 11:45 PM | Joined: Feb 2003 Posts: 1,377 'Bolter | | 'Bolter Joined: Feb 2003 Posts: 1,377 | Could also be a bad tire  | | |
#36715 08/29/2003 10:53 PM | Joined: Sep 2001 Posts: 272 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 272 | Does it drive OK until 35-40 and then feel like the van is about to shake apart? If so then it is a 99% chance it is a INNER CV JOINT. Try lifting the front , letting the wheels hang and shake the inner joint. You will probably get a loose or grinding feeling as the wheel is turned BY HAND. If so replace the whole axle they are cheaper than just a joint and usually carry a lifetime warrenty at most chain auto stores. When you replace it undo the sway bar on both sides, remove the 15mm pinch bolt from the balljoint, and PRY DOWN HARD. Be careful you dont mess up the new joint the inner joints are spring loaded internally. also there are no keeper clips on the trans side it will just slide out. You will loose some trans fluid so be sure to have the right type on hand. Good Luck Brad | | |
#36716 08/30/2003 2:38 AM | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | I had the exact same symptoms in my 1995 Caravan. Luckily it was just a bad front tire. It looked fine,(good tread, no bumps or bubbles) but that was the problem. I hope yours is that simple.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
#36717 08/31/2003 2:51 AM | Joined: Jan 2003 Posts: 13 Member | | Member Joined: Jan 2003 Posts: 13 | why are we talking nopar on the stovebolt page ? that is a shame | | |
#36718 09/03/2003 2:35 PM | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | a little lower, and pulled the valve cover and found an intake push rod had gone through the rocker. but with the mess of the motor i decied to put a second hand motor with 25,000 km on it. | | |
#36719 09/03/2003 8:42 PM | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | :confused: :confused: :confused:
#36720 09/03/2003 8:45 PM | Joined: Jul 2003 Posts: 29 Member | | Member Joined: Jul 2003 Posts: 29 | Albert...did that fix the shimmy in your go-mobile? :p
Use a big enough catapult and even pigs can fly...remember nothing is impossible, impractical yes, but never impossible.
