7 members (Johnny Rib, dwreills, Gdads51, Rexville48, Wayne67vert, Wickedbass, Peggy M),
147
Mod | | | Forums66 Topics128,036 Posts1,055,460 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 12 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 12 | On a 41 GMC on the doors on the interior they have a trim/ molding/ whatever it's called, piece that goes from the bottom of the window up and around the door frame back to the other side to the bottom of the window. Mine on both doors is a two piece unit. I would have thought these would be 1 piece unit. When placed into their proper position there is a smell gap between them like they were cut at some point. Does anyone have any information on this? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I moved this here from General Truck Talk before I knew you had posted in the proper place too. Please, no double posting.
You can delete this by hitting the edit button. | | | | | Joined: Mar 2000 Posts: 784 'Bolter | | 'Bolter Joined: Mar 2000 Posts: 784 | The Chevy is the same way. There is another small trim piece that you are missing that covers the gap. It's only about 1/2" wide and is screwed in to the door to cover the gap. If I remember right it goes from the top of the window trim all the way around and hooks under the edge of the window opening. Hope this helps George | | |
