4 members (Otto Skorzeny, rfs56trk, Bill Hanlon, 1 invisible), 81 guests, and 0 robots.
Topics128,119
Posts1,056,313
Members48,439
#365420 01/25/2008 3:46 AM
Getting ready to box the frame on my 1958 GMC Suburban Carryall so I can mock-up the 454 big block and 700 R4 trans with the mounts. I have four-cored the original radiator, but I'm unsure whether or not I need a fan clutch. I'm not putting in air conditioning,so is the only issue noise with a constantly running fan, or is there also a cooling concern with no fan shroud?
Never accept a drink from a urologist!
My experience with big blocks is that they run hot. I'd do everything possible to cool it off.
The most important thing you should do is use a well constructed fan shroud but a fan clutch will help with noise and mileage much better than a flex fan I hate them things.
The difference between men and boys is the price of their toys.
Grant from Roy, Washington
1956 6100 Chevy Dump Truck in the Gallery
1964 GMC Drump Truck in the Gallery
user
http://s1301.photobucket.com/user/56Taskforce/slideshow/
Riding in the Passing Lane
You must have a fan shroud unless the fan is real close to the radiator.
1972 Chevy c10 Cheyenne Super
I'd remove the fan that you got and put in an electric one with a thermo switch.
~Jenny
"Custom can't be bought. It's achieved one cut at a time."
1950 Chevrolet 3100 1/2-Ton
Thanks one and all for the replies. I would not use a flex fan, and I was considering an electric push fan in lieu of a stock 17" fan. I know a fan shroud will focus the airflow better, but I don't know why a fan clutch would better help to cool, unless it is a thermal clutch. Now, where to get a shroud to fit?
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
They say a pull fan is better to use if you can. The fan isn't blocking part of the radiator of the air as you go down the road & w/a pull fan w/a shroud you're directing the air through a designated area. You could even do it LIKE THIS....Joe
#366589 01/27/2008 9:14 PM
Leo Offline
Moderator
Moderator
A proper fitting fan shroud is a must. I don't have a clutch fan in my 396 and I have managed to cool it down a lot. I also went to a thinner coolant called 40 below. Old Sub is right, these engines tend to run quite warm and because of their weight (mine weighs 670 pounds) you need every advantage you can get.
Leo #367992 01/30/2008 9:22 AM
Pair of electric fans with shroud if you are NOT going to tow. Engine Fan with clutch, Fan shroud and pusher electric fans IF you ARE going to tow. Did I mention the fan shroud?
SPAL and TriPac make the most powerful commercially available (to the general public) electric fans that I know of.
Scott
PS, did I mention the fan shroud
I have two big blocks, both running on synthetic oil. ( I also have some big block F#$ds on synthetic, including my 37ft MH )
I have an electric fan on the 396 with a stock 55 chev rad, and I have never had a problem in the 32 years the fan has been on the engine.
My 454 has a clutch fan, and although I have run Fexalite fiberglass fan, I prefer the clutch fan.
Bob
55 Cameo 396 TH 400 with overdrive
65 Caliente conv
67 BB Caliente conv
67 Mercury 1 Ton
76 GMC 3/4 ton 454ci
84 Buick Turbo Regal
