6 members (Bill Hanlon, fonz8261, Shaffer's1950, tclederman, Hotrod Lincoln, Charles in CA), 70 guests, and 3 robots.
Topics128,087
Posts1,056,376
Members48,442
#36613 07/18/2002 6:51 PM
I have a 51 GMC 1/2 ton long bed, original engine and transmission, that I wish to keep, I am looking for venders that I can get perforamce parts for this set-up, also any help from you all would be gratefully received.
#36614 07/18/2002 8:08 PM
Patricks
and
Stovebolt Engine Co
Owners are both former presidents of Inliners International and will have anything you need for a 270, including good advice even if it may conflict at times.
#36615 07/20/2002 12:48 AM
Not to get knitpicky or anything, but a '51 GMC 1/2 ton would have had a 228 originally, not a 270. The 270 was only available in 450 series trucks in up.
Either way, the links above wrote the book on performance stuff for the 270 (or 228, 248, 302 etc) and they are the best in my opinion too.
TONS of upgrades you can do and you're only limit is your wallet!
Sky's the limit! Good luck and giddy up!
