1 members (TexasA&M48Truck), 67 guests, and 3 robots.
Topics128,082
Posts1,055,964
Members48,430
#36611 05/07/2004 6:06 PM
Just finished installing heavy duty tie rod and tie rod ends from ccp,on my 51,3100,the job took about 3hours all the tips from you guys helped alot. I had to drill out the old ball ends and then drive them out with a punch,not bad at all,I really think this is a worth while upgrade, especilly when you compare the old tie rod assy with the new, GO FOR IT. old navy 51..............
#36612 05/08/2004 2:44 AM
Glad the change went smooth. I have my old tie rod removed, the ball ends gone, and waiting for the CPP rod to show up. And I'll still need to call for those urethane boots for the drag link ends. I guess Chevy Duty is the only place with the urethane boots, although Jim Carter has rubber ones. cool
