7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible),
105
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,956 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 37 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2006 Posts: 37 | I have a chance to pick up a '90 Merc Couger for free. Does anyone know if the front suspension is similer to a mustang II and if it is something that could be used under my '53 half ton? Thanks Don
"Sometimes my luck is so bad that if I bought a pumkin farm, halloween would probobly be outlawed."
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If the '90 is the same as a '93, no it is not the same. | | | | | Joined: Oct 2006 Posts: 4,983 Master Gabster | | Master Gabster Joined: Oct 2006 Posts: 4,983 | It's an IFS but it won't make a U turn in the alley.
~Jim
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Not the same. It's a modified strut suspension, no upper control arm. All Fox platform cars ('79-93 'Stang, T-Bird, Cougar, Bobcat, Fairmount/LTD, Marquis) all use the same suspension. What you need to look for is the '74-'78 Mustang or the '71-'79 Pinto for the correct suspension. Also, the Maverick and Comet use that suspension. Would probably be easier/cheaper to get an aftermarket crossmember than try to hunt one of those cars. You'll get a better part that way.
Bill Burmeister | | |
