1 members (1 invisible), 105 guests, and 3 robots.
Topics128,024
Posts1,055,395
Members48,422
#36588 08/07/2002 11:18 PM
OK, last year I picked up a NOS fram oil filter for a 42 Olds. I wanted to install this on my 216 in my 46 Chevy 1/2 ton however, I did not have the correct mounting bracket. The engine in the truck is a rebuilt 48. Last week a guy gave me a bunch of cast off parts he had left over from his attempted restoration of a 52 3100 panal truck. In the junk was what I figure to be the correct mounting bracket for my engine. Before I do this I have some questions for the experts, who frequent this site.
1. The filter is supposed to hang off the intake manifold, correct?
2. If so should it be in front or behind the carb?
3. Will it pay to add this filter?
4. Where do the lines hook up to the engine (a diagram or picture would be helpful) ?
Thanks in advance for your sage advice.
#36589 08/07/2002 11:45 PM
Check out this thread...
oil filter thread
54 3100 with 235
62 flatbed dump C60 with 261
#36590 08/10/2002 1:39 PM
Thanks for the hint.
#36591 08/10/2002 4:07 PM
Can that same canister be used when converting to a full flow filter system on a 235?
The lines should probably have a larger I.D., but I wonder about the tiny openings on the housing and pipe channel.
Is it really necessary to do the conversion, if the oil gets changed regularly?
Wouldn't the oil pressure drop also?
Btw: Are there any oil additives that really make a difference in performance or preserving the engine?
I have heard that some truckers have used toilet paper rolls as the filter element :p
... does that really work?
On the road every day...
1952 Truck - 235
1948 Coupe - 261
