9 members (DoubleB, Hotrod Lincoln, Tiny, Rosco, smeyer6, SNOYL, frogfarmer, ShopRag, Dakota Bob),
143
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,292 Posts1,058,590 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2006 Posts: 17 Apprentice | | Apprentice Joined: Aug 2006 Posts: 17 | Does anyone know if there is a repop/stamping of the 54/55 grille top bar without the "CHEVROLET" stamped into it?
That, or can anyone suggest how we can remov/fill-in the lettering on a standard grille top piece so that it can be chromed after the modifications?
Sorry if I offended anyone, but we are working on a custom 54 truck and would like to preserve the unique 54 look but remove all external badging.
Thanks, Thomas
| | | | | | Houston54 Unregistered | | Houston54 Unregistered | Thomas, I have never seen a top grill bar without the letters stamped in it but you could always fill them with body filler and then add whatever you want to put on it. What did you have in mind? Something Odd like "Pontiac?  | | | | | Joined: Nov 2007 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 80 | In order to chrome it ,you will have to revert to old school methods and shrink and metal finish it.you can't chrome over body filler.Any filling you may have to do can be done with brazing rod. Good luck finding a body man who knows how. | | | | | Joined: Mar 2005 Posts: 576 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 576 | i would assume that a quality plating shop would be able to fill those for you.........dave 1949 Chevrolet 3100 "When this thing hits 88 miles an hour, you're going to see some serious sh%t." -Doc Brown
| | | | | Joined: May 2005 Posts: 147 Shop Shark | | Shop Shark Joined: May 2005 Posts: 147 | I have two grills one with and one without, body filler works if you just want to paint it. Guess you could cut out the script and carefully weld in a new panel.
| | | | | Joined: Aug 2006 Posts: 17 Apprentice | | Apprentice Joined: Aug 2006 Posts: 17 | LOL, "something odd".  Since we are cloning the 54 to a "Pontiac" truck, I had just wanted to remove the CHEVROLET badging. Nothing spectacular. I've often thought about the brazing in the lettering and then chroming on top of it, but I am not brazing expert. If anyone else comes up with some good ideas, lemme know, I'm open to suggestions. | | |
