| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36554 05/04/2005 7:01 PM | Joined: Feb 2005 Posts: 7 New Guy | | New Guy Joined: Feb 2005 Posts: 7 | i am wondering if any body knows if the 6 cylinder stands are different from the v-8 stands and also which bolt hole locations are for which motor. thank you very much
STEVE C.
#36555 05/04/2005 7:11 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | They are the same 230/250/V8,292 has diff pass side, they both go in the rear holes for V8/230/250, pass side(diff stand) in front set for 292. 67-72 V8 stands in the front holes will put V8 forward about 3" or so, but not correct for these years(63-66). Brian | | |
#36556 05/04/2005 7:16 PM | Joined: Feb 2005 Posts: 7 New Guy | | New Guy Joined: Feb 2005 Posts: 7 | hey thanks alot. i must have the 67-72 stands because in the front holes all my driveshaft and linkages are the right length. with these stands do i just need to drill a new hole for the bottom stand hole, it is the only one that doesn't line up
STEVE C.
