1 members (Hotrod Lincoln), 49 guests, and 6 robots.
Topics128,021
Posts1,055,355
Members48,420
#36554 05/04/2005 7:01 PM
i am wondering if any body knows if the 6 cylinder stands are different from the v-8 stands and also which bolt hole locations are for which motor. thank you very much
STEVE C.
#36555 05/04/2005 7:11 PM
They are the same 230/250/V8,292 has diff pass side, they both go in the rear holes for V8/230/250, pass side(diff stand) in front set for 292. 67-72 V8 stands in the front holes will put V8 forward about 3" or so, but not correct for these years(63-66). Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#36556 05/04/2005 7:16 PM
hey thanks alot. i must have the 67-72 stands because in the front holes all my driveshaft and linkages are the right length. with these stands do i just need to drill a new hole for the bottom stand hole, it is the only one that doesn't line up
STEVE C.
