2 members (lumbersawyer, 78buckshot), 167 guests, and 3 robots.
Topics128,142
Posts1,056,474
Members48,441
JC
Offline
Hi,
My 250 6 cylinder I put in my 66 c20 has a harmonic balancer with about an inch of side to side play in it. I don't imagine this is normal. What would cause this problem?
Also, I have access to a 292 6 harmonic balancer. Would it work on the 250? Thanks!
JC in KC
"The future will be better tomorrow." Dan Quayle
1965 Chevy C10 Long Fleetside
Riding in the Passing Lane
Hy Jon. It,s probably all wallerd out. You need to pull it & see. Hopefully the crank is O.K.. The 292 won,t work.
George
1972 Chevy c10 Cheyenne Super
Wrenchbender Ret. is correct, I'd head to the local salvage yard to get another one...yours is beyond hope...I'd say the problem was
it got a little loose and was ignored..
Geoff
68 GMC 3800
56 JD420C w/JD90 Loader
JC
Offline
George, you are very right. Wallered out keyways in the crank and and harmonic balancer. I have a used balancer on it now and there isn't as much play, so I'll be in a little better shape, but I think I am going to go with a 292 engine in the near future. Thanks for the input!
JC in KC
