0 members (),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,292 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | i doubt my hoist will clear the core support. i'm parting this truck anyway...should i remove the front clip? is the clip easy to remove as a "unit"? thanks | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy bucket, seeing as how nobody else has answered you, I'll give it a try, yes the whole front clip can be removed as a unit and it will give you the best view when removing the engine. If you're going to part it out anyway then you will already have the clip ready to go should anyone want it. There will be bolts at the top and bottom of the fenders, and there may be some in the door jamb as well, then probably under the rad support, then lift it off with your engine lift and set it aside, there will also be wiring and possibly other things that are connected between the cab and front clip, hope that helps. | | | | | Joined: Jun 2001 Posts: 169 'Bolter | | 'Bolter Joined: Jun 2001 Posts: 169 | Bucket,
I just pulled the 350 V8 from a 1972 C50 and only removed the radiator and front accessories. I didn't even remove the hood. Chained the engine very close to the hook and was able to clear everything.
The '72 is very similar to the '68.
Paul | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I removed my 4-53T from a 78 GMC 6500, it was simple, I think the fenders stayed, but removed grill radiator, and core support all as one. I used a crane, so the hood came off too.
Grigg | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | One time I took off the front clip and the next time it was just the hood and radiator support. If you are parting it out, I'd take off the clip and make it easier. | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | If you have a crane to go high enough you can pull them without pulling the hood or the radiator. Time you take the fan off you have nothing but space. I used to pull them in an hour back in my younger day,s. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 6 New Guy | | New Guy Joined: Jan 2008 Posts: 6 | I pulled a small block out of a 66 C60 about 2 weaks ago. I removed the hood and radiator and used a chain hoist in barn. | | |
