Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (Peggy M, Wayne67vert), 159 guests, and 5 robots.
Topics128,281
Posts1,058,471
Members48,490
#36519 12/06/2004 7:30 PM
Junior Member
Junior Member
Hey Guys,
Quick question; I have a 66 Chevy 1/2 ton with what is supposed to be a 250. I pulled the # off the boss behind the distributor but have had no luck running it down. So the # is FO717TCJ, any idea? Thanks,
MikeP
#36520 12/06/2004 7:53 PM
That looks like a serial number. Try looking for the casting number on the passenger side of the engine. I hope this helps.
Dano
69 C10 LWB 250 L-6/3spd
79 C30 Crew Cab Dually 454 V-8/TH-400
"Takes more than a coat of paint to make it at Thunder Road!"
#36521 12/07/2004 4:17 AM
According to your numbers, it's a 1970 250 ci that had a 'glide behind it, built in Flint on the 17th day of July.
That's what I came up with,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#36522 12/07/2004 12:42 PM
I show TCJ as a 1980 Blazer/Jimmy 250
http://no25.homestead.com/page3b.html#1980
#36523 12/07/2004 2:25 PM
Junior Member
Junior Member
Thanks for the help. I have the original build sheet when the guy bought the truck new and the engine # does not match. Kinda thought that it was a newer model engine.
MikeP
