8 members (Gdads51, Steelonsteel, TUTS 59, Mike Burns, Mike'sPlace, Wickedbass, moparguy, 1 invisible),
98
Mod | | | Forums66 Topics128,065 Posts1,055,870 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36462 03/24/2004 9:00 PM | Joined: Aug 2003 Posts: 28 Junior Member | | Junior Member Joined: Aug 2003 Posts: 28 | Any problem putting a 292c.i. inline 6 in a '72 Nova? Like the right engine mount which is forward of the left mount? How much taller is a 292 than a 250? Really don't want a hood scoop or whatever, but...........? Using 700R4 trans. | | |
#36463 03/24/2004 7:52 PM | Joined: Feb 2000 Posts: 5,206 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,206 | The 292 is 1.750" taller than the 250. The rest is the same. Water pump will be higher as well. The motor mount location will need to addressed. There is a adaptor the should work for this, you may need to hit the salvage yards to find one. Chevrolet didn't change the frames for different engines, they adapted the engine to the frame. Joe | | |
#36464 03/25/2004 4:52 AM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | I think one problem will be the air cleaner clearance. You might have to make an adapter and mount it elsewhere.
Fred 52 3600 69 C-10
