1 members (stoveboltgator), 218 guests, and 0 robots.
Topics128,048
Posts1,055,540
Members48,425
#36439 04/11/2004 12:02 AM
I have a exhaust valve on #5 cylinder stuck open. Supposed to be a 235. Any good way too unstick with out pulling head? Second question Truck was advertised as a 53 but appears to be a 54 model Grill, interior. 1 piece Windshield. I read some where Jobmaster ,Loadmaster, and Thriftmaster engines were different colors this one's gold. Haven't located casting number under grease yet but block # is 0106411T547
Appreciate any suggestions
#36440 04/11/2004 2:44 AM
H Online: Content
Get some Kroil, and give it a good soaking from the top side, and after a couple of days, tap the top of the stem gently with a ballpeen hammer to see if it will move. Alternately pry up, and tap, and if it moves at all, it should free up.
www.kanolabs.com
Kroil is one of the best penetrating oils I've ever used, even frees up rusted engines with a little time and work.
#36441 04/11/2004 2:48 AM
I asume you have valve cover off to know it is # 5
try some P B Blaster penertrating oil on stuck parts lots of it let sit over night Start motor tap lightly on parts to free valve.
It has worked for me, add some marvel mystery oil to crankcase do not over fill it also helps free things up. Has motor sat long without runing? Let us know how you make out Bill
#36442 04/11/2004 12:54 PM
Thanks for the suggestions. I have some PB Blaster on hand so will try that also is the Kroil available other than mail order?
#36443 04/11/2004 4:03 PM
H Online: Content
Some gunshops carry Kroil, as it's an excellent rifle bore cleaner when mixed with another cleaner called Shooters' Choice, but the simplest way to get it is an online order directly from the manufacturer. It's made in my hometown, Nashville, and I buy direct from the factory. I've got a gallon on hand just about all the time.
#36444 04/11/2004 7:10 PM
A good hardware store should stock it. My favorite local Hardware Sales has it in spray cans and by the gallon.... grin
#36445 04/16/2004 11:47 PM
grin grin Success After leaving valve soaking with PB Blaster and 3in 1 oil. I went out tonight to spread spring for another coat and it popped loose. That KROIL still intrigues me. Thanks for your suggestions
