1 members (baldeagle),
34
Mod | | | Forums66 Topics128,003 Posts1,055,244 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | this seems like a silly question but...
how is the air filter housing secured to the air horn on the top of a mono rochester b? there are no threads for the rod in the cross piece on top of the carb. is the rod supposed to be a press fit? | | | | | Joined: May 2002 Posts: 155 Shop Shark | | Shop Shark Joined: May 2002 Posts: 155 | Some air cleaners use a clamp around the horn instead of the post.. You could cut threads in the bar for a post...
Geoff
68 GMC 3800 56 JD420C w/JD90 Loader
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The crosspiece hooks under notches in the neck & small split pins go down & lock it in. Often the neck is wallerd out & won,t hold the bracket. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | the cross piece is there and secure. the oil bath was sitting on the passenger floor and no threaded rod was to be seen. the oil bath looks to be original and it has a hole in the top, no clamp at the bottom.
i may just jb a threaded rod into the notch on the cross piece. | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | There is a Clamp on pipe with a cross bar and centre rod with wing nut which holds and supports the oil bath air cleaner.... | | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | thanks. anyone have pictures? | | | | | Joined: Mar 2007 Posts: 863 Shop Shark | | Shop Shark Joined: Mar 2007 Posts: 863 | I'll try to send pics tonite.... | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | The oil bath air cleaner does not fit that carb. It is a latter model & uses a dry cartridge type filter. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Sep 2006 Posts: 73 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2006 Posts: 73 | huh?? this is the original carb (at least a correct carb) for a 1960 261. my shop manual indicates the oil bath is the only option. | | |
