3 members (Phak1, kades51, TUTS 59), 241 guests, and 2 robots.
Topics128,095
Posts1,056,067
Members48,433
Does any one know the part number or numbers for a 1964 C50 Chevy truck with a 2 speed axle? What's the best way to test to see if the vacuun shift is working or not? I have gotten under the truck while in netural and let my son engage the two speed but I don't hear any noise while pulling the knob in or out.
3B Offline
Hy mule 1951, what part numbers are you looking for, does the engine change its sound while your working the control?
I would make sure your lines are connected, if so I would take em off and make sure their clear, not clogged up. You should be able to tell real quick. Mine makes a clear click noice, you can hear it move. It might effect the engine rpm, but I dont think I have ever noticed that. You could also pop the cover off and see if the diaphragm looks ok. Maybe Napa might have a kit, just a guess, good luck.
