5 members (KEVINSKI, jmoore, MTD91, fonz8261, 1 invisible), 392 guests, and 2 robots.
Topics128,268
Posts1,058,395
Members48,485
#362806 01/19/2008 3:25 PM
any chance anyone know where I can find information on wheelbase?track width front and rear? for task force suburban. Thanks for any help you guys can pass along
you know your a gearhead when you pick up food to eat at the shop after wrenching all day, and you reasoning for not washing your hands is a little grease makes all food taste better
the assembly manual, and a 1/2T burb will be the same as a 3100 1/2T pickup
BILL
Flxible #362982 01/19/2008 11:36 PM
Don't have one, any chance someone can help me out? Reason i ask is I've seen some pictures which seem to suggest a 1974 suburban frame fits quite nicely under a 1959 suburban. Wondering if any one has any details/confirm denie or even a few dimensions to get me headed in the right direction
I could be wrong, but the 59 used the short wheelbase and the 74 used the long wheelbase, so, if possible, you would have to shorten the 74.
51 Chevrolet Canopy Express
02 K25 Duramax Crew Cab
wheelbase of the TF 1/2T's is 114"
wheelbase of 74 C10s was 117.5"
outside body width of the TF panel/burb is about 76" .... I think you'll find the 74 chassis is too wide
Flxible #363102 01/20/2008 5:03 AM
'73-'91 Suburban wheelbase-129.5, Front track width-65.8, rear track-62.7
Bill Burmeister
so according to longbox/red, this MIGHT be feasible, if u cut down the length?
I wouldn't try it grin
Flxible #363897 01/22/2008 1:40 AM
I've seen a few project where guys think they will slap the truck on a different frame. They find out very quickly it's alot easier said then done. Some of the projects I've seen finished you can tell the truck is on a different frame cause it just doesn't sit right.
A few things to think about if your going to be using a newer frame.
Body mounts
Gas filler system
Shorten frame
Shorten Drive shaft.
Shorten Brake lines
Park brake cables will need to modified
Gas line shortened
Steering system
Rad support
That's just a few things I came up with. There's probably more. Wouldn't be a lot easier updating the original frame?
38 original
48 panel
59 stepside
46 in the back forty
I have no idea like I said, that's why I came here. You always hear about S10 swaps for the AD's. I was wondering if there was anything similar for the task forces, like I said, came across a suburban that supposedly has a 74 suburban frame under it, but guy I talked to, didn't know a whole lot about the truck (stupid car sales man. Thanks for all the help guys.
