7 members (Phak1, GMCJammer51, D B Cooper, treegrower, 2-Ton, 55shaker, 1 invisible),
123
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,095 Posts1,056,072 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2004 Posts: 67 'Bolter | | 'Bolter Joined: May 2004 Posts: 67 | Does any one know the part number or numbers for a 1964 C50 Chevy truck with a 2 speed axle? What's the best way to test to see if the vacuun shift is working or not? I have gotten under the truck while in netural and let my son engage the two speed but I don't hear any noise while pulling the knob in or out. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy mule 1951, what part numbers are you looking for, does the engine change its sound while your working the control? | | | | | Joined: Feb 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 190 | I would make sure your lines are connected, if so I would take em off and make sure their clear, not clogged up. You should be able to tell real quick. Mine makes a clear click noice, you can hear it move. It might effect the engine rpm, but I dont think I have ever noticed that. You could also pop the cover off and see if the diaphragm looks ok. Maybe Napa might have a kit, just a guess, good luck. | | |
