| | | Forums66 Topics128,284 Posts1,058,526 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36331 01/03/2004 2:57 AM | Joined: Sep 2003 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 50 | After spending much time and piecing together my 235 for swapping into a '54 half-ton I discovered I was sold 216 lifters. (DOH!) I should've been able to tell right away 'cuz boy they are different than the stock 235s. But...having never seen either before I was shnookered. Now I'm trying to figure out whether to order the hydraulics or solid lifters for a 235 cam. The cam gear is composite so the camshaft must be for hydraulic lifters. How can one be sure whether their cam is for hyd or solid lifters and does it matter other than the gear? Are the lifters interchangeable to the cams? Did cam specs change depending on the type of lifters used? It seems there would be some differences for the changed lash. :confused: Thanks for any help. | | |
#36332 01/03/2004 5:26 AM | Joined: Dec 2000 Posts: 506 Shop Shark | | Shop Shark Joined: Dec 2000 Posts: 506 | More importantly is the block drilled for hyd lifters? When you had the block apart you may have noticed if down in the lifter bores if they were cross drilled? If not hyd cam won't work. Some blocks were drilled some not.
"Drugs are money, money is power, power is security." - Kent Heiner Nedrow population 2212 Carbon footprint family of 2/11 tonnes of CO2/yr
#36333 01/03/2004 6:26 AM | Joined: Sep 2003 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 50 | Thanks for the heads up. Yes, the lifter bores are cross-drilled with a fairly large gallery running through all twelve bores front to back. So I have a hydraulic block, and a composite cam gear which lead me to conclude that I need order hydraulic lifters. I did some basic online research and apprised myself of tech concepts like "lash ramp" on camshafts! If by some freak chance the cam I've got is for solid lifters (despite having the composite gear on it) will there be a problem mating hydraulic lifters to it? Will the lash ramp disrupt driving performance? | | |
#36334 01/03/2004 6:57 PM | Joined: Dec 2003 Posts: 2,733 Shop Shark | | Shop Shark Joined: Dec 2003 Posts: 2,733 | My advice would be to replace the composite gear with a new aluminum one. A bit noisier but a lot stronger. I believe that all 55' and newer 235 engines were cross drilled for hydraulic lifters whether equipped with them or not.
I just rebuilt mine and used hydraulics with the new cam because I don't like to listen to the clacking of solids unless it is a full out race engine. Also I intend to drive it a lot and don't want the bother of adjustment. | | |
#36335 01/04/2004 1:04 AM | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A hydraulic cam should have the same lift on intake and exhaust. You can tell nothing by the gear type. trucks are the only ones to use aluminum gears originally. I have used hyd lifters on solid cams a couple of times and they worked fine. Make sure you fill and bleed them first as per shop manual or you can trap air in lifter and end up with noisy lifters.
See the USA in your vintage Chevrolet! My Blog | | |
#36336 01/04/2004 6:17 AM | Joined: Sep 2003 Posts: 50 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 50 | Thanks all for the input: you've answered my questions! Hydraulics it is. | | |
