5 members (Joe H, 78buckshot, baldeagle, Shade Baby, Gdads51), 70 guests, and 7 robots.
Topics128,014
Posts1,055,329
Members48,419
#36323 02/10/2003 11:29 PM
Junior Member
Junior Member
Not sure which motor my 1966 C15 has in it. The numbers stamped in the block are 38771780. Farther back on the block by the dipstick is CON2K65 Can anybody help?
#36324 02/11/2003 12:35 PM
From inliners.org the closest casting # puts you at 62-78 230/250
http://www.inliners.org/casting/numbers.html
YOu need the stamped code next to the distributor to narrow it down. Once you ahve that, visit
http://no25.homestead.com/page3.html
#36325 02/11/2003 8:32 PM
Junior Member
Junior Member
Thanks Chuck, I have looked at the site you suggested, and the number near the distributor. Oddly enough, there isn't a 230 listed for 1966..only the 292 and 250. The number matches the 250, assuming a 230 doesn't have the same number! Thanks for your help.Any advice on making the six a little hotter when I rebuild it?
#36326 02/12/2003 1:00 PM
Visit www.inliners.org for lots of tips. You can plan on the usual bolt-ons, better breathing with headers and an improved intake (4 barrel or multi-carb), a hotter cam, good ignition. Mine is at http://www.chuckthetruck.homestead.com/page15.html
There are a lot of really hot sixes out there, depends what you want to do with it. Ken is working on a supercharged and/or Miller cycle 292 that oughta be a real torquer. It might be running now - haven't heard an update in a while.
