| | | Forums66 Topics128,020 Posts1,055,345 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#36323 02/10/2003 11:29 PM | Joined: Feb 2003 Posts: 29 Junior Member | | Junior Member Joined: Feb 2003 Posts: 29 | Not sure which motor my 1966 C15 has in it. The numbers stamped in the block are 38771780. Farther back on the block by the dipstick is CON2K65 Can anybody help? | | |
#36325 02/11/2003 8:32 PM | Joined: Feb 2003 Posts: 29 Junior Member | | Junior Member Joined: Feb 2003 Posts: 29 | Thanks Chuck, I have looked at the site you suggested, and the number near the distributor. Oddly enough, there isn't a 230 listed for 1966..only the 292 and 250. The number matches the 250, assuming a 230 doesn't have the same number! Thanks for your help.Any advice on making the six a little hotter when I rebuild it? | | |
#36326 02/12/2003 1:00 PM | Joined: Jan 2001 Posts: 662 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 662 | Visit www.inliners.org for lots of tips. You can plan on the usual bolt-ons, better breathing with headers and an improved intake (4 barrel or multi-carb), a hotter cam, good ignition. Mine is at http://www.chuckthetruck.homestead.com/page15.html There are a lot of really hot sixes out there, depends what you want to do with it. Ken is working on a supercharged and/or Miller cycle 292 that oughta be a real torquer. It might be running now - haven't heard an update in a while. | | |
