1 members (KEVINSKI), 160 guests, and 2 robots.
Topics128,108
Posts1,056,230
Members48,436
#363257 01/20/2008 6:02 PM
Does anyone have any info about roof racks for a 61 panel. I use my panel as a daily driver for my handyman business and occassionaly need to carry longer lengths of lumber that wont fit inside. I assume there are period correct racks but I have never seen any. I am also going to put a request in the parts wanrted as well.
Thanks, Mac
I believe that this subject has been talked about before,do a search. From what I have seen, the station wagon racks are the same.
Couldnt find any info doing a search. Never thought about the wagons being the same.
Mac
I found it, not much info. I know I have seen a few 60/66 Suburbans with the wagon type rack.
https://www.stovebolt.com/ubbthreads/ubbthreads.php/ubb/showflat/Main/34127/Number/247096#Post247096
Thanks for the thread. I'll try to track down eitherthe direct bolt or gutter mount.
Mac
My understanding after re-reading your post, your intentions are to carry oversize lumber. I am not sure if any of the luggage racks were intended for such loads and would carefully search for information regarding such use. You may want to check with a specialty truck store that caters to construction/tradesmen. I think your idea of a gutter mounted rack is a better idea than an original bolted through the roof mount. If you check ebay, try searching for: luggage rack, roof carrier, roof rack etc. also there are later model racks, both foreign and domestic that might adapt to your roof, so take measurements and compare. Good luck!
This is one style that was available in the 50's and 60's
http://sfbay.craigslist.org/nby/pts/545521611.html
