7 members (Lightholder's Dad, Otto Skorzeny, KEVINSKI, lumbersawyer, BC59, tclederman, 1 invisible),
67
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,154 Posts1,056,853 Members48,456 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 2,420 Former Workshop Owner | | Former Workshop Owner Joined: Nov 2004 Posts: 2,420 | I am planning to switch my torque tube differential and tranny for an open driveline. This will be for a '41 half ton that will also get a newer transmission hopefully a T-5. Would this be a good choice?
As described by the seller
Dana 35C rear axle from '91 Jeep Commanche pickup. Will fit all years of Commanche pickup (MJ) '84-'92 & Cherokee (XJ) from '84-'01. The "C" means it's a C-clip axle. C-clip axles were used in all '91 through '01 model rear axles. Has 3.08:1 gearing. Had new brake drums & shoes installed with about 500 miles on them before pinion bearing failed. No other component damage. All internal parts are fine. Axle Shafts alone are worth more than what I'm asking. Was going to use the axle shafts for wife's '94 Grand Cherokee but they will not work. The housing will need to have new shock mounts welded back on.
Would this be a good candidate, are the gears too high for a manual tranny? I am going to measure my drum spacing to compare widths, as I might check it out this weekend.
Or is this unit not a good choice, it sounds like I can get it cheap.
~ J Lucas 2006 GMC Envoy 4.2 I6 2023 Ram 2500/Cumins 6.7 I6 2010 Jeep Grand Cherokee (Wife’s) 2002 Silverado 2500 Gas 6.0 1941 Chevy 1/2-Ton 1942 Chevy 1.5-Ton SWBIn the Gallery My Flicker Photos! | | | | | Joined: Dec 2004 Posts: 1,897 Shop Shark | | Shop Shark Joined: Dec 2004 Posts: 1,897 | A dana 35 is pretty light duty. A dana 44 or dana 60 would be stronger. The gears are a bit high for an overdrive as 3.08 gears are already almost considered an overdrive.
I think you would be happier with a stronger rear. The one mentioned would probably live pretty well behind a 235, but the gears aren't that desireable with an overdrive... unless the OD ratio is about a 0.85:1. For all practical purposes 3.55 to 4.11 gears would perform the best. the 3.55 being on the economy side, and the 4.11 being better towing or hill climbing gears. A 4.11 ratio is effectively a 3.0 ratio with a standard .73 overdrive. | | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | They would almost need to pay you before it would be a good deal. The cost of repairs could easily be more than the cost of a better unit in servable condition.
On the other hand the gears could work okay if you have enough power. I have 3.08 gears under my '55 GMC Suburban and am pretty happy with them. I have 3.07 gears in a Corvette with an overdrive and it performs great. I wouldn't use either to pull a trailer though.
The GMC has a 270 and the 'vette is a 'vette...
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | My first impression is no, the Dana 35 is not very desirable C clip axles are no good in my opinion (disc brakes would help some with that) The 3.08 is more than likely geared to fast with an OD transmission. Don't yet know width and bolt pattern?
If I had a 1/2 ton with 4 speed, the bolt pattern and width of the axle were right on, and it was less than $100 and less than an hour away, then I would give it a try, and probably be happy with it. Sounds like that's not the case for you.
Grigg | | | | | Joined: Sep 2006 Posts: 1,276 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 1,276 | I would say the best choice would be to use a F@rd 9" they can be found in many widths and are easily modified for any application. | | | | | Joined: Mar 2005 Posts: 86 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 86 | The 70s and 80s Wagoneer axles are pretty tough & narrow. You can keep the 6 bolt lug pattern also.
JC in KC "The future will be better tomorrow." Dan Quayle 1965 Chevy C10 Long Fleetside
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The 70s and 80s Wagoneer axles are pretty tough & narrow. You can keep the 6 bolt lug pattern also. If one were to go that route, might as well use a 12 bolt from a '73-'76 Blazer and keep all Chevy! And get a stronger axle, too.
Bill Burmeister | | |
