1 members (tesa),
59
0
Mod | | | Forums66 Topics128,076 Posts1,055,925 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 21 Apprentice | | Apprentice Joined: Jan 2008 Posts: 21 | Well thanks to a couple of fellows in the big bolt section that have answered 2 of my questions and one I did not ask they now have given me the need to ask a couple more here in this site the help here is great anyway to the questions. It seems I am the proud owner of a 1953 3 ton truck with a 248 engine. The odometer reads 18000 miles truck has not been used since the mid 70s. Now my questions 1 can it be run on unleaded fuel without the use of lead substitute or will it need to be rebuilt with the hardened valve rods. 2 will it maintain 50-55 miles per hour speed limit as if I dont have to change the drive train I would like to keep it as close to original as possible and I plan on driveing it daily. I believe that trucks of this period have class and deserve to keep working heck its only a year older than I am and I still work. Thanks for your help. | | | | | Joined: Sep 2006 Posts: 49 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 49 | Interesting question about the fuel. I have a 1972 Toyota Landcruiser, with the original 6 cylinder. It was designed to run on regular gas. I do not remember when unleaded fuel started being made, but it must have been about this time. The reason I say this, is because in my owner's manual, Toyota includes a note that says that if unleaded fuel is used, it must be 91+ octane. I don't know if that statement is true or not. I have owned the Landcruiser for 12 years. I have always put 91+ octane in it and have had no problems with the engine. It uses no oil and runs like a top. From time to time, I will run it at 65-70 mph. At 70 mph, the engine is really screaming, since the transmission is a 3 speed. I think the rear end is a 3.7. But, I'm not sure. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Congratulations on your new aquisition.
As for the fuel question, doing a search will yield mixed opinions. My advive is to drive it the way it is and if it needs a teardown at some point, talk it over with your machinist.
Your truck will probably cruise at less than 50 mph. I would think that 45 mph would be cranking it pretty good. There are many on this site that can tell you from experience. | | | | | Joined: Sep 2006 Posts: 49 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 49 | Well, once again, I have shown my ignorance on the mechanics of the vehicles I own. I stated earlier that I thought my Landcruiser had 3.7 gears. WRONG! They are 4.11. Wanted to correct myself, before someone else corrected me. Not that there are a lot of 'Bolters out there that have '72 Landcruisers. But, you never know.
However, this thread was about fuel, and my statement still stands. | | | | | Joined: Jan 2008 Posts: 21 Apprentice | | Apprentice Joined: Jan 2008 Posts: 21 | Thanks guys that answers a lot of ?s for me it was suggested over on the big bolt forum that the engine is a 248 GMC but I will add the engine serial # here as I should have done in the first place engine serial # is g42224. I have a axle that is currently in a 1991 school bus its an International with disk brakes but as the I already own the bus and have the elictic brake system and the rims and matching front axle I can update the brakes and rims and rear end all at the same time. The bus was a deisel with a automatic transmission will the engine and tranny in the 53 work with enough power to get her up to speed. | | |
