1 members (Hotrod Lincoln), 95 guests, and 1 robot.
Topics128,049
Posts1,055,677
#3614 05/25/2003 9:39 PM
Well, I have decided to overhaul my 305 V6. I looked at Kanter's website, and they have an overhaul kit for $750.
It includes just about everything to rebuild this engine. Except for the connecting rods, or motor mounts. They don't even have the con rods or the mounts available. But they do have the rod bearings. I dont mean to sound cheap or anything, but is there another company that sells an overhaul kit for this engine that has the connecting rods and guides with it? I mean, it sounds like a good idea to replace the rods too, if you are doing the pistons and everything else, right?
Jonathan S. Keffer
Certified Yeti Trainer
Richard Roy Schlicht-
Good Grandfather, Veteran Wrench Turner...
"If it ain't broke, fix it 'till it is..."
Es gibt nichts, zu befürchten, aber befürchtet sich.
#3615 05/26/2003 2:21 AM
You might try Egge Machine Co. They do obsolete engine parts. I know the 305 isn't obsolete, and the don't list it in their catalog, but they might have info on who does.
Knuckle Buster
I ain't hidin from nobody,
Nobody's hidin from me.
Mr. Breeze
#3616 05/26/2003 3:28 AM
talk to yer local machine shop [who yer gonna get to do the machining anyway] and see what they can do for parts pricing - won't necessarily have to replace rods unless they been abused - ya won't get the whole job done for a good price if yer gonna replace everything 'just cuz' - there surely will be a supplier right there in Orygun who'll have everything for an engine like that . . .talk to NAPA even . . . .
#3617 05/26/2003 3:59 AM
I agree with "squeeze", try NAPA. I got my re-main kit from them cheaper than Kanter, but had to use Kanter for the timing chain and timing gears. NAPA can usually find what you need but might take a few days.
It might be worth your while to call Kanter if you haven't already to see what they can do. When you get you parts check to see if they are the right ones- especially bearings. Read my posting "lesson learned" and you'll read why.
smile
jim
1965 Chevy C-10 Longbed Stepside
#3618 05/26/2003 7:21 AM
I don't know if you can get them cheaply, but it may be a good idea to go with forged rods and pistons on this motor since they are not known for strength under revs, then maybe you can get more power out of it. Get it balanced if you can afford it.
Paint & Body Shop moderator
#3619 05/26/2003 5:28 PM
on the engine mounts you can get them from Steel Rubber in Denver North Carolina. Look them up on the net.
$55.00 a set, they re-rubber your old mounts
JAke
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
#3620 05/26/2003 8:17 PM
Talk to Matt at Hublers engines, tell him I sent you.
http://members.ebay.com/aboutme/[email protected]/
