0 members (), 82 guests, and 2 robots.
Topics128,090
Posts1,056,378
Members48,442
#36172 06/07/2002 5:12 AM
I installed a 305 in a 55 chevy pickup and the exhaust manifold outlet is in the way of the steering linkage. Is there a manifold for a 305 that exits between the firewall and first sparkplug rather than between the 1rst and 2nd plug?
Steve
#36173 06/08/2002 12:40 AM
In a Task Force truck, a set of Ram's horn manifolds works well. I understand that on 1st series AD trucks, relocation of the steering box is necessary to obtain clearance for a V8 installation.
Alternatively, the engine could be offset to the pass. side an inch or so............shouldn't hurt anything.
Heck, most F O R D S are like that, with the engine off-center to make up for the drivers weight. (so I have been told by a F O R D aficionado) :rolleyes: .
*** GMC ***
#36174 06/08/2002 12:47 AM
smoran-I read somewhere that you could try a passenger's (right) side manifold on the left side of the engine. You would just have to run a longer exhaust pipe on that side.
Wannabe smile
P.S. Maybe you could check out the stock manifolds on a late model LT4 F-body (Camaro/Firebird). If memory serves, they kick way up, the tops are even with the tops of the valve covers.
"Don't expect anything and you'll never be disappointed"
