| | | Forums66 Topics128,260 Posts1,058,321 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 96 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2007 Posts: 96 | Am looking for wheels that will help get the front wheels under the fenders on my 49. I have installed the front IFS from a 78 1/2 ton. It is about 7 incehs wider than the stock one. I am considering narrowing it 1.5" as Mobileortho has done with his 3600, but that still will not be near enough. I am also planning to lower the front end using drop spindles and springs to match the flipped rear (dropped 6"). I would like to know if there are soem factory 5 lug on 5.0" bolt circle wheels out there with LOTS of backspace. I have heard wheels from a late model Impala SS might work, but do not have any specs on them. I would like to have same wheels front and back so can rotate and have one spare. Don't really care what size, 15, 16 or 17".
Mobileortho - have seen some past posts from you with links to others that have done this swap. Any wheel advice ? | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | You may want to consider a custom set of Weld Wheels. Then you can order them in any offset. The only factory wheels I know of with that large of an offset are either Corvette Wheels (4.75" BC) or Duallies.
| | | | | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Ignoring the bolt pattern issue, I wonder if Corvette wheels will fit on that IFS. I tried to put Corvette wheels on an older car once and had tie rod issues, which I suspect would happen on most anything not designed for that much offset.
Check Chevy van wheels for fit. I know others have used G20 Van wheels successfully.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | G20 wheels will be the same as C10. As to the Impala SS wheels, they have the same backspace as the truck wheel. They also will not fit onto the truck hubs (although the truck wheels will fit the Impala, that's what GM used for the police car package). Going aftermarket will be the best bet. Most wheel makers (Weld, American Racing, Wheel Vintiques, Early Wheel Company, Stockton) will make you a set of wheels in any offset/backspace you want.
Bill Burmeister | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 |
Bill Burmeister | | | | | Joined: Dec 2005 Posts: 1,026 'Bolter | | 'Bolter Joined: Dec 2005 Posts: 1,026 |
Robert C. If it's true what they say, "You learn from your mistakes," I'm a Genius in the making. 1950 3600 | | |
