9 members (Peggy M, JoeDude, Hotrod Lincoln, Perro, 48jim1ton, Shaffer's1950, Stovebolt48, Donf, 1 invisible), 93 guests, and 3 robots.
Topics128,032
Posts1,055,516
Members48,425
#361327 01/16/2008 8:54 AM
Apprentice
Apprentice
I have a 1963 chevy pickup an I put a sbc 350 in it an I need help with hooking the battery up I got the v-8 wiring harness but I heard you have to hook the battery back the way it was at that is postive ground an - on the hot side. If anyone knows what I'm talking about could you help an if u need more info just ask me an thanks for the help
Brandon Seal
chevyman_08 #361333 01/16/2008 10:00 AM
not 63 thats neg ground
32fire2 #361334 01/16/2008 10:01 AM
Apprentice
Apprentice
so in 1963 they came out with neg ground
Brandon Seal
Z
ZooKeeper
Unregistered
ZooKeeper
Unregistered
Z
Chevy has been neg ground for yearssssssssss before 63. Even the 50 model stuff was neg ground...Joe
Brandon,
Chevrolet has never been positive ground...they have always been negative ground. You might be thinking of early GMC trucks which were positive ground.
A big red cable goes to the starter solenoid and a big black cable attaches to the engine block or a mounting bolt on the starter.
The positive post on the battery is a larger (top post style) diameter than the negative post. Both post are usually marked with a + and a -.
If Chevrolet ever did produce a positive ground vehicle, it was when Moses was a small boy! Good luck! smile
atomarc #361572 01/17/2008 12:17 AM
Apprentice
Apprentice
ok thanks for the help but alot of people told me it had postive ground because it had a generator
Brandon Seal
chevyman_08 #361585 01/17/2008 12:39 AM
Riding in the Passing Lane
A lot of people are wrong.
1972 Chevy c10 Cheyenne Super
Apprentice
Apprentice
So hook the battery cables up like u would a newer model car an it will not fry my wires are anything. because all the wiring under the hood is new an do not want to replace them.
Brandon Seal
you got it, the generator doesn't change anything, and unless you short something out, nothing can fry yer new wiring, certainly not the polarity, which as said above has always been negative ground on Chevys
Flxible #361615 01/17/2008 1:30 AM
Apprentice
Apprentice
thanks alot to all of yall
Brandon Seal
chevyman_08 #362062 01/18/2008 12:10 AM
Not to but in, but the neg cable on the battery gets grounded to the grill support panel. The pos cable connects to the starter, but also has a small wire that runs across the grill support panel and comes out at the voltage regulator and connects to what looks like the horn relay. Hope this helps, I own 2 1966 Chevy trucks. If you have all new wire harnesses and new battery cables, then you do not have to worry about this wire, everything will work fine.
Shawn
Trucks? Kids? whats the difference?
