| | | Forums66 Topics128,048 Posts1,055,541 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2008 Posts: 37 Apprentice | | Apprentice Joined: Jan 2008 Posts: 37 | I have a 1963 chevy pickup an I put a sbc 350 in it an I need help with hooking the battery up I got the v-8 wiring harness but I heard you have to hook the battery back the way it was at that is postive ground an - on the hot side. If anyone knows what I'm talking about could you help an if u need more info just ask me an thanks for the help
Brandon Seal
| | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | | | | | | Joined: Jan 2008 Posts: 37 Apprentice | | Apprentice Joined: Jan 2008 Posts: 37 | so in 1963 they came out with neg ground
Brandon Seal
| | | | | | ZooKeeper Unregistered | | ZooKeeper Unregistered | so in 1963 they came out with neg ground Chevy has been neg ground for yearssssssssss before 63. Even the 50 model stuff was neg ground...Joe | | | | | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Brandon, Chevrolet has never been positive ground...they have always been negative ground. You might be thinking of early GMC trucks which were positive ground. A big red cable goes to the starter solenoid and a big black cable attaches to the engine block or a mounting bolt on the starter. The positive post on the battery is a larger (top post style) diameter than the negative post. Both post are usually marked with a + and a -. If Chevrolet ever did produce a positive ground vehicle, it was when Moses was a small boy! Good luck!
| | | | | Joined: Jan 2008 Posts: 37 Apprentice | | Apprentice Joined: Jan 2008 Posts: 37 | ok thanks for the help but alot of people told me it had postive ground because it had a generator
Brandon Seal
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | A lot of people are wrong. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2008 Posts: 37 Apprentice | | Apprentice Joined: Jan 2008 Posts: 37 | So hook the battery cables up like u would a newer model car an it will not fry my wires are anything. because all the wiring under the hood is new an do not want to replace them.
Brandon Seal
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you got it, the generator doesn't change anything, and unless you short something out, nothing can fry yer new wiring, certainly not the polarity, which as said above has always been negative ground on Chevys
Bill | | | | | Joined: Jan 2008 Posts: 37 Apprentice | | Apprentice Joined: Jan 2008 Posts: 37 | thanks alot to all of yall
Brandon Seal
| | | | | Joined: Oct 2007 Posts: 1 New Guy | | New Guy Joined: Oct 2007 Posts: 1 | I have a 1963 chevy pickup an I put a sbc 350 in it an I need help with hooking the battery up I got the v-8 wiring harness but I heard you have to hook the battery back the way it was at that is postive ground an - on the hot side. If anyone knows what I'm talking about could you help an if u need more info just ask me an thanks for the help Not to but in, but the neg cable on the battery gets grounded to the grill support panel. The pos cable connects to the starter, but also has a small wire that runs across the grill support panel and comes out at the voltage regulator and connects to what looks like the horn relay. Hope this helps, I own 2 1966 Chevy trucks. If you have all new wire harnesses and new battery cables, then you do not have to worry about this wire, everything will work fine. Shawn
Trucks? Kids? whats the difference?
