| | | Forums66 Topics128,087 Posts1,056,000 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I have a 66 Chevy stepside with straight 6,3 on the tree. I would like to change it to an automatic trans, does that make sense? Would there be enough power from the 6 cylinder? | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | Yes. Trucks older than your 66 have come with an auto and 6. I would recommend picking up a newer overdrive trans, such as a 200r4 or 700r4 to get overdrive.
| | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | Where would be a good place to start looking for the parts I will need. I think I need a different steering column, of course a new trans, different peddles.
Thanks | | | | | Joined: Nov 2002 Posts: 2,766 Carburetion specialist | | Carburetion specialist Joined: Nov 2002 Posts: 2,766 | You will also need a different carburetor. Carburetors for engines with automatic transmissions are calibrated 1/2 size to 1 size RICHER to compensate for the fluid coupling heat losses (one reason why an automatic will never get as good mileage as a manual with the same gearing). Failure to change carburetors will result in major idle issues.
Have never gone this way, but have made many conversions the other direction (remove automatic, install manual). Average fuel economy saving with the manual is 15~20 percent.
Jon. Good carburetion is fuelish hot airThe most expensive carburetor is the wrong one you attempt to modify. If you truly believe "one size fits all," try walking a mile in your spouse's shoes!The Carburetor Shop | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | Well it is getting to be to much and with the cost of gas I better stick with the 3 speed. What I need to do now is rebuild my steering column because when you shift, it locks up sometimes. What is the best way to take care of that problem. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Rocky - the shifter locking up is slop in the shift box on the column under the hood - open it up, clean out the old gummy grease and insure that the slot and pawls in there are in good shape and the spring in it is sound - regrease and try it again - also may need adjusting, which procedure should be in your shop manual .... you do have a shop manual, don'tcha?  Bill | | | | | Joined: Aug 2007 Posts: 1,859 Grumpy old guy playing with trucks, cars, and boats | | Grumpy old guy playing with trucks, cars, and boats Joined: Aug 2007 Posts: 1,859 | I would put a 5-speed behind the engine vs the 3 speed.
| | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | Thanks Bill I guess I will be getting a shop manual. But do I have to read it too :hammering: LOL
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I believe the 66 has the shift mech. built in the column. You will need to tear down the column & build up the levers & adjust the lower brg. I like Scotts suggestion. The 5 speed is easier swap then the auto.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I am lost on that 5 speed do you mean manual on the floor? | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I am lost on that 5 speed do you mean manual on the floor? Yes. A lot of Stovebolters are getting the T-5 manual 5 speed from mid 80,s S-10s & putting it in. It gives you syncro. forward gears & an o-drive for the highway. There is info in the Tech tips & lots of posts on the subject the last few months. If you are satisfied with your 3 speed it will still be easier to repair the shift column.
They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | Also I was wondering, I guess I am trying to decide the best way to go, is there a better steering column maybe a different year that would work better. What I don't like about my column is that it is to close to the driver and there isn't any room. It needs to be closer to the dash. | | | | | Joined: Apr 2005 Posts: 641 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 641 | just put a floor shifter in for your 3 speed | | | | | Joined: Feb 2001 Posts: 4,095 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 4,095 | a t-5 out of a s-10 truck or a camaro, is a good choice. go to tech tips on this site and read about it. i have one on my 54 and i love it. ron
Ron, The Computer Greek I love therefore I am.1954 3100 Chevy truckIn the Gallery 2017 Buick Encore See more pix1960 MGA Roadster Sold 7/18/2017
| | | | | Joined: Dec 2007 Posts: 150 'Bolter | | 'Bolter Joined: Dec 2007 Posts: 150 | I went to tech tips but it didn't sound very easy to do. Were should I get a trans at a recking yard? And what about the clutch that sounds like the hard part. | | |
