4 members (Gdads51, carbking, David Bush, 52Carl), 82 guests, and 9 robots.
Topics128,078
Posts1,056,029
Members48,433
#361447 01/16/2008 6:27 PM
On my 66 3/4 Ton long bed the rear seems to sag a bit.
The previous owner said the guy he bought it from had a Camper on it most of its life.
I would get the leafs re conditioned but I am unable to locate any that can do it in my area.
Is their a way I can do a simple quick fix by lifting the rear end by 2" or so?
Not as good as having the leafs re-arched, but you could always just bolt on some overload shocks. Or even air shocks if you wanted to be able to adust for heavier loads.
TruckNut
Be kind, courteous, cheerful and helpful - And someone will take advantage of you.
"Quiting smoking is easy, I've done it hundreds of times." Mark Twain
There MUST be someone in the Bay area that does spring service. Any spring company worthy of it's name can do this.
1953 Chevy 5-window 3100
More pix on Picturetrail
Dave
Engine & Driveline Moderator
I just replaced the shocks with Monroe Gas charged.
I thought this would fix it. It drives about 85 % better but is still a little low in the back. I wish I would have went with some coil over adjustable.
Shocks will not fix low ride hight, they only serve to dampen the action of the spring. The only exeption to this would be an air shock, and that's not really what they are intended for.
Bill Burmeister
