6 members (46 Texaco, Shade Baby, BarryP, Oswald, Robert Crandall, dt235sd), 92 guests, and 2 robots.
Topics128,162
Posts1,056,910
Members48,458
#361416 01/16/2008 5:02 PM
Apprentice
Apprentice
Hi Bolters, I lost the link I had to a source of carb rebuild kits: 1930 truck with a brass bowl Carter C RJH 08. Thanks gang, Terry J
TerryJ #361422 01/16/2008 5:24 PM
If you join the Vintage Chevrolet Club of American we have a guy that does Carb rebuilds and runs them on an engine before he returns them to you. Look up "Chip" Sweet. He knows his Carter Carbs.
34 & 35 trucks are the greatest
Apprentice
Apprentice
Thanks 35 T, I'm a pretty good wrench, but I'm not at all ignoring the value of an expert "old Carter" guy like Chip. Thanks for the tip. At this point I think I'll tear the carb down to clean it up prior to firing up the old Bolt for the first time in 35 years. I do not know if the engine is any good at all yet, so a pro rebuild of the carb would be a waste until I prove that. I would put a kit in the carb if I could find one, but if not I'll make the gaskets and do with a de-gunking. Thanks, TerryJ
TerryJ #361561 01/17/2008 12:03 AM
Be real careful with the carb teardown they break very easily.
The Filling Station lists a kit and parts for that carb.
And yes, be careful that you don't break anything.
Cleon
1949 Chevy 6400
1931 Chevy Firetruck
Apprentice
Apprentice
Thanks Guys, I just ordered a kit from the Filling Station. I'll be very careful. I'll keep ya posted. TerryJ
TerryJ #361953 01/17/2008 8:22 PM
The only reason I recommened Chip is that he makes sure all the little vacuum and fuel internal passages are cleaned out also; in order to do that you have to remove the little rivet plugs. And he runs the carb on an engine to make sure it's perfect.
