0 members (),
133
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 30 Apprentice | | Apprentice Joined: Dec 2007 Posts: 30 | Hi Bolters, I lost the link I had to a source of carb rebuild kits: 1930 truck with a brass bowl Carter C RJH 08. Thanks gang, Terry J | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | If you join the Vintage Chevrolet Club of American we have a guy that does Carb rebuilds and runs them on an engine before he returns them to you. Look up "Chip" Sweet. He knows his Carter Carbs.
34 & 35 trucks are the greatest
| | | | | Joined: Dec 2007 Posts: 30 Apprentice | | Apprentice Joined: Dec 2007 Posts: 30 | Thanks 35 T, I'm a pretty good wrench, but I'm not at all ignoring the value of an expert "old Carter" guy like Chip. Thanks for the tip. At this point I think I'll tear the carb down to clean it up prior to firing up the old Bolt for the first time in 35 years. I do not know if the engine is any good at all yet, so a pro rebuild of the carb would be a waste until I prove that. I would put a kit in the carb if I could find one, but if not I'll make the gaskets and do with a de-gunking. Thanks, TerryJ | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | Be real careful with the carb teardown they break very easily.
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | The Filling Station lists a kit and parts for that carb. And yes, be careful that you don't break anything. Cleon | | | | | Joined: Dec 2007 Posts: 30 Apprentice | | Apprentice Joined: Dec 2007 Posts: 30 | Thanks Guys, I just ordered a kit from the Filling Station. I'll be very careful. I'll keep ya posted. TerryJ | | | | | Joined: Apr 2005 Posts: 261 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2005 Posts: 261 | The only reason I recommened Chip is that he makes sure all the little vacuum and fuel internal passages are cleaned out also; in order to do that you have to remove the little rivet plugs. And he runs the carb on an engine to make sure it's perfect.
