5 members (52Carl, klhansen, Otto Skorzeny, farmallb, rick46ia), 75 guests, and 13 robots.
Topics128,021
Posts1,055,354
Members48,420
#360949 01/15/2008 3:02 PM
Ok here we go again , I did a search on this but I still need some opinions on which sub frame is best suited for my 54 1/2 ton GMC , I do have access to a 70s ws6 t/a sub and a 68 camaro sub Which is the best and easiest [dimension wise] to use???
I put over 700 miles on my '56 yesterday with stock suspension. I see no need to change suspension. Running 350, auto.
Cletis #360994 01/15/2008 4:33 PM
I have a 89 tpi 350 700r4 and a 3.23 disc brake rear to put in it , I want to upgrade and lower the truck also.
Tom,
Like Cletis, I have put a gob of miles on my strait axle truck in the recent past as well. I have 6000 miles on my 53 in about 8 months. Unlike Cletis, I see every reason to update the suspension. I have a '74 Nova sub frame that is going in my truck soon. It is the exact same clip as the '68 camaro's. The cool thing about this clip is that it is the same width (frame and backing plates) as your truck is now. You can also easily adjust the height on this sub frame so you can lower you truck.
Already set up for a small block, power steering, disc brakes, etc... Everyone uses this clip for a reason.
I understand the purists, but if you want to put in a drive train that isn't original, you might as well improve your performance and drive-ability while you're at it.
My brother's 56 F100 is set up like this and it is AWESOME!
1953 Chevy 1/2-Ton 3100 5-Window
1937 Chevy 1/2-Ton
1970 Chevelle
