| | | Forums66 Topics128,021 Posts1,055,349 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 51 | Ok here we go again , I did a search on this but I still need some opinions on which sub frame is best suited for my 54 1/2 ton GMC , I do have access to a 70s ws6 t/a sub and a 68 camaro sub Which is the best and easiest [dimension wise] to use??? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I put over 700 miles on my '56 yesterday with stock suspension. I see no need to change suspension. Running 350, auto. | | | | | Joined: May 2007 Posts: 51 Wrench Fetcher | | Wrench Fetcher Joined: May 2007 Posts: 51 | I have a 89 tpi 350 700r4 and a 3.23 disc brake rear to put in it , I want to upgrade and lower the truck also. | | | | | Joined: Jan 2007 Posts: 70 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2007 Posts: 70 | Tom,
Like Cletis, I have put a gob of miles on my strait axle truck in the recent past as well. I have 6000 miles on my 53 in about 8 months. Unlike Cletis, I see every reason to update the suspension. I have a '74 Nova sub frame that is going in my truck soon. It is the exact same clip as the '68 camaro's. The cool thing about this clip is that it is the same width (frame and backing plates) as your truck is now. You can also easily adjust the height on this sub frame so you can lower you truck.
Already set up for a small block, power steering, disc brakes, etc... Everyone uses this clip for a reason.
I understand the purists, but if you want to put in a drive train that isn't original, you might as well improve your performance and drive-ability while you're at it.
My brother's 56 F100 is set up like this and it is AWESOME!
